I have a Toshiba Satellite laptop purchased in USA and have now moved to New Zealand. Can anyone help me change the region? I'm blonde. Thanks
The free VLC player ignores DVD region codes.
My suggestion or Baldrick's are better, but if you really do want to change the region of the DVD drive to 4 (I think NZ is in 4) then just put a region 4 DVD in the drive and you'll be prompted to change it. Drives can be changed 5 times and the 5th change locks the drive permanently in that region.
Toshiba Satellite black screen no post
By MJA in forum ComputerReplies: 6Last Post: 3rd Feb 2012, 20:41 -
Change region code, how? Toshiba portable DVD player (SD-P1400) 2004 model
By Traxx29 in forum Portable VideoReplies: 0Last Post: 27th Dec 2009, 19:42 -
how to change DVD player region code on Toshiba SDk 730
By sashatheman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Dec 2009, 07:17 -
Change Sony BDP- S350 From Region (1) to Region (4) can it be done?
By MOTHGIRL in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Sep 2008, 22:58 -
Toshiba Satellite Vista laptop won't recognize ram upgrade
By edong in forum ComputerReplies: 17Last Post: 25th Jul 2007, 22:49
