Just got my new laptop 3 days ago, and I've noticed that the right-click is relatively slow considering that it's a new laptop...
Sony VPCEB1E0E Intel Core i3330M 213GHz Processor 3GB PC38500 DDR3 SDRAM 320GB Hard Drive
Takes like 2-2.5 seconds...
Results 1 to 11 of 11
Something odd there.
Check your Task Manager or at least your hard drive light to see if there is a lot of HDD access or CPU or RAM usage. Maybe a anti malware program is checking the menu first.
You could also check your mouse settings, but I don't think there is a setting for that. Have you tried a different mouse or tried the touchpad or similar R click button to see if they work better? -
I did check everything...I've uninstalled MCAfee but still no change
I've even tried a new mouse but still the same...
Do you think it might be something wrong with the laptop? -
by the way, if I press right-mouse for my computer or recycle bin, then I get it instant, only the right mouse click on the desktop takes 2 seconds.
Sounds like CPU getting pegged out somehow.
The shellexview method described here has worked for some people (see comments below the article, maybe you'll recognize a program that's on your laptop):
http://www.watchingthenet.com/how-to-fix-slow-right-click-problems-in-windows.html
Seems to work for some people, but not everyone. Might be worth a shot. -
2D + Context menu handle issue
1: Run regedit
2: Locate > HKEY_CLASSES_ROOT\Directory\Background\shellex\Con textMenuHandlers
3: Left click on "ContextMenuHandlers" to highlight it and then file > export , call it CMH.reg ... your backup
4: Leave "new" alone ... it'll be one of the other values causing the issue which should be removed
5: Post what is found under this key if unsure -
How to add to the Right Click Dropdown Menu
By jollyjohn in forum ComputerReplies: 6Last Post: 13th Apr 2011, 21:59 -
Right click (mouse) not working?
By jh1966 in forum ComputerReplies: 8Last Post: 3rd Feb 2010, 01:21 -
Imburn with Shrink one click?
By jyeh74 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jan 2010, 11:13 -
Is it possible to re-arrange right click
By mn072065 in forum ComputerReplies: 2Last Post: 11th Jun 2009, 22:20 -
Click encode and nothing happens.
By painofmind in forum ffmpegX general discussionReplies: 7Last Post: 5th Jan 2009, 15:26
