I know this has been an issue discussed in threads before, but I haven't seen any commentary to put this issue to rest once and for all.
Using TMPGEnc 4 Xpress, I routinely transcode music videos from various sources to mp4 for use with AppleTV. The end result is always an audio skew of approximately -135ms (audio too early). Quicktime will play it this way, and with iTunes and AppleTV it is even more noticeable, but other applications don't seem to show much of a sync problem.
So, in order to correct this, I have to process each clip with a correction of +135ms so it will play right in iTunes, AppleTV, and QuickTime players.
Not knowing this was an issue, I created a library of over 300 videos with sync problems, and have spent months recompiling the original material and preparing it to be reencoded with the proper correction.
What I really want to know now is, WHY does this happen? Is the codec poorly written? Is it merely the way it interacts with the software I use, or is it a configuration problem that I'm just to ignorant to pick up on?
Results 1 to 1 of 1
MP4 Issue On Xbox 360 (please Help!)
By Cornholio77 in forum Media Center PC / MediaCentersReplies: 9Last Post: 31st Dec 2011, 23:09 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 10:57 -
DVD to .MP4 for Iphone using XviD4PSP audio sync issue
By Tearren in forum Video ConversionReplies: 4Last Post: 6th Jun 2010, 21:14 -
Is it possible to fix a sync issue on a converted file (mp4)
By AndyD in forum AudioReplies: 3Last Post: 23rd May 2009, 21:28 -
Mp4 sync issue...
By sonnenkind in forum Video ConversionReplies: 8Last Post: 24th Feb 2009, 22:27
