I am in the process of figuring out how to go from .wtv to DVD. I did not like Microsoft DVD Maker or Media Center's built-in utility for this.
I can convert from .wtv to .mpg without too much trouble, edit the .mpg with Womble MPEG2-VCR, and use FAVC to create DVD files. The resulting video looks much better than what either of Microsoft's utilites produces, especially color fidelity.
There is one more thing that I would like to do with FAVC, if possible -- remove the pillar boxing on 4:3 video broadcast at 1080i, prior to resizing to DVD resolution. Is there some way to do this using the options in the "Advanced Scripting" tab?
Never mind. I kept searching, found some clues that led me to avisynth's crop function, and figured out the rest on my own.
After setting up everything else, go to the "Advanced Scripting" Tab
For 1080i recordings, type Crop(240,0,-240,0) into the "Preceding the Resize Operation" input box. For 720p recordings, use Crop(160,0,-160,0) instead.
Check "Don't Start Batch File"
The video's aspect ratio would normally still be flagged as 16:9 when converted to DVD instead of 4:3 as it should be. FAVC doesn't have a setting to override the source aspect ratio. That can be corected in the batch files FAVC uses. Wait for FAVC to say it is done creating the custom batch files.
Go to your documents folder, or whatever location you specified for Temporary files. Open the folder labeled "Working Folder X" (where "X" is a number). Find the file labeled Title0.ini and open in Notepad. Change "ASPECT" from 16:9 to 4:3 and save. I only had one title, but there may be other .ini files to change if you have additional titles.
Run "Title.bat"Last edited by usually_quiet; 2nd Apr 2010 at 16:36. Reason: Clarity, spelling and punctuation
I used to use FAVC, however the last couple of releases had some issues, development stopped, and I looked elsewhere. AVStoDVD uses many of the same tools, including HCEnc for encoding, has more features, is actively developed and supported here by it's author, and is a better tool. Well worth checking out.
Read my blog here.
Ripbot264 doesn't crop if resizing to 720p?
By sparriskrigaren in forum Blu-ray RippingReplies: 3Last Post: 16th Jul 2012, 06:53 -
letter and Pillar boxes
By fester77 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2011, 14:43 -
Resizing is changing the colors on me -Solved!
By star099 in forum Video ConversionReplies: 9Last Post: 13th Mar 2011, 19:03 -
How do I get rid of letterboxes and pillar boxes
By Tyrod in forum Newbie / General discussionsReplies: 3Last Post: 6th Feb 2009, 14:30 -
Crop Without Resizing in Premiere?
By meldavid in forum EditingReplies: 9Last Post: 10th Aug 2007, 16:06
