Hello,
I have some mini dv footage recorded some years ago- 4-6 years- on a different camcorder than the one I'm currently using, a reconditioned cheap JVC I bought to use for playback for video editing, and the sound doesn't play with some of these tapes, the video editing can't find a timecode, and there's a slight clicking sound when I play the tapes, about 6/sec. I re-recorded some of these tapes, and the recording and playback works fine, with no clicking noise. Any suggestions? (I'd hate to lose the tapes, they contain valuable archive lectures.)
Thanks,
dave24
see if the cam has settings for 12bit and 16bit audio. if it doesn't it may not play one of the DVavi audio types.
Several possibilities. Could be an LP speed recording, or else (most likely) it's a mismatch between 12bit/4-channel audio and 16bit stereo. (EDIT: aedipuss also suggested that as I was typing this.) It could even be a head tracking mismatch between old and new camcorders (though I would think it would affect the picture as well).
What are you using for DV transfer? Try WinDV.
http://www.kiva.org/about -
Thanks for the quick feedback- the cam does have settings for 12 bit and 16 bit, and SP and LP, and I've tried all 4 combinations for playback- none work with these tapes, but I can record in any combination on the same tape. Re.: the DV transfer, I don't think it's a problem with the capture, as I have the same problem with playback using just the cam- and I still get the same weird ticking sound, it almost feels mechanical, when the problem part of the tape is played, and it even precedes briefly the beginning of the video portion, while the video continues to seem OK. Also, I don't get any of this with a new recording with the same tape. Any other suggestions would be welcome, and I'm also planning to play the tapes on another cam or deck, to see if the problem is particular to this cam.
Thanks,Dave24 -
Quick feedback to your quick feedback,
12 vs 16 Kb or LP vs SP is in the tape as recorded. You can't change this in playback.
It is what it is.Recommends: Kiva.org - Loans that change lives.
Capturing Mini-DV video with the proper date and time
By Raucko in forum Newbie / General discussionsReplies: 7Last Post: 27th Dec 2010, 13:04 -
Blu-ray or rip movies don't play in 5.1 surround sound. Help?
By Obamargarine in forum Software PlayingReplies: 1Last Post: 15th Feb 2009, 17:07 -
Need to play corrupted mini-DV tapes
By funcrew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 31st Dec 2008, 15:26 -
video and audio don't have the same time?
By just in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2008, 07:17 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 03:11
