Hello,
I have two related questions as outlined bellow
Q1. Is there any free good software that I could use to first, convert a small home video file to individual (each frame - about 300) images and second, do some changes and third, use those image file to recreate a video file?
I used a converter (DVEVideosoft) to get .jpg images of all the frames and used windows movie maker to put them back, but it came out as a slide show instead of as a movie. Doesn’t look like movie make have much choice in changing fps.
Q2. What is the best image format for something like I’m describing above. .jpg didn’t give good quality image.
Thank you in advance for your time![]()
12virtualdub, file->save as images.
2. virtualdub, open first image and all should be loaded. -
Yes, you can choose the output format in the dialog that pops up when you select Export->Image sequence.
Thanks, I see that you can Export the images in different formats. Sorry I did not look
can't get ffmpeg to convert video to image sequence
By wiseant in forum Video ConversionReplies: 15Last Post: 12th Apr 2013, 09:37 -
Help with lossless ffmpeg command [video => png => back to video]
By vidgem in forum EditingReplies: 12Last Post: 15th Nov 2011, 11:30 -
Convert Single Image to Video
By Deluge in forum Video ConversionReplies: 5Last Post: 19th Sep 2010, 08:24 -
Software to convert a letterboxed video back to true widescreen?
By gastrof in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2009, 16:39 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
