I have a AG-1980 that is making a pretty loud squealing sound when it is rewinding tapes or ejecting them. Before I take a closer look inside the machine to pinpoint the problem. I was wondering if anyone had any further insight or prior experience with this issue on a AG-1980.
VCRs use rubber belts and rollers and have brake pads for the reels. Any of them could cause a squealing noise. They probably need cleaning, or worst case, belt or roller replacement. Probably best to do before it eats a tape.
I think it might need a belt or roller replacement to be honest, I am going to clean them and hope that it fixes the issue.
Do you know of a place I could maybe buy parts for this unit or or if buying a broken AG-1980 and using those parts is my only option... which I know is not ideal for replacing parts like pinch rollers and belts. -
Tapes can do this too, not always the VCR.
It does it with any tape, I bought it like this from ebay for dirt cheap. The deck plays perfect, but I wanted to address the squeaking before it became an issue that would cause pyhsical damage to the tape or the deck. If cleaning does not work I will buy a service guide and try to track the belts and rollers down.
TV makes a buzzing sound when scenes are bright.
By Denvers Dawgs in forum Newbie / General discussionsReplies: 10Last Post: 30th Nov 2011, 12:32 -
My AG-1980 suddenly won't play tapes. Any suggestions?
By Mini-Me in forum Capturing and VCRReplies: 5Last Post: 26th May 2011, 16:47 -
Benq 1620 tray will not open? Just makes a click sound.
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 23rd Jul 2009, 01:12 -
Panny 1980 vs JVC 9911 vs ???; what's your preference and why?
By videobruce in forum Newbie / General discussionsReplies: 5Last Post: 6th Jul 2009, 14:15 -
¿How to make VHS-C tapes play well on AG-1980 VCR?
By CCEncoder in forum Capturing and VCRReplies: 0Last Post: 20th May 2007, 08:23
