  1. I'm trying to convert a whole CD as 1 MP3 track. I don't want the CD broken up to 61 tracks (yes, 61 tracks) and I want it to play as 1 track for the whole CD. Does anyone know how to do this in the settings with either musicmatch or eazyCDcreator? Or if there is a program you know of that does this besides these 2? Thanks!
  2. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Hi there,
    All you need to do is to download Exact Audio Copy from the link below
    http://www.exactaudiocopy.de/eac6.html
    Once downloaded and installed choose the Copy Image & Create Cue Sheet, from the Action along the top.
    What this will do is to create a cue sheet and convert the cd as a .Wav file.
    You can then convert the .Wav into MP3 using any Mp3 converter.
    You can even setup Exact Audio Copy to convert the CD to Mp3 format using an External Mp3 converter.
    Hope this helps ya
