Help!
I have Sony XDCAM EX-1 footage edited in Premiere CS3 and need to export my sequence to mini-dv tape.
I have a Canon HV20 camcorder.
When the image shows up in the HV20 monitor, it's cropped on all sides by black bars.
How do I keep the widescreen aspect ratio from the EX-1 footage on the mini-dv tape?
The Canon HV20 has a widescreen monitor, so I don't understand why the aspect ratios aren't the same.
Thanks!
I created 2 sequences - the second one is set to 1440x1080HDV, but the aspect ratio is still smaller than the HV20 monitor.
I bought regular mini-dv tapes.. -
to write back to HDV tape it has to be HDV spec on the timeline. make sure the the hdv project setting "adjust source material to match project settings" is checked. i don't think most ex-1 footage is HDV spec to start with, so expect a long conversion if it's not.
miniDV tape is HDV tape, they use the same type. make sure the HV20 is set to record in HDV and it should probably say HDV in on the screen, not DV in.--
Thanks for taking the time to help me. I really appreciate it
I'm looking for the "adjust source material to match project settings" right now. -
sorry i was wrong. i didn't think cs3 exported to HDV only cs4. so i was recommending to use vegas. this part of the cs3 manual says it does though.
http://livedocs.adobe.com/en_US/PremierePro/3.0/help.html?content=WS1c9bc5c2e465a58a91...aef7-7ca1.html
the same, set an HDV project at the start, applies to cs3 and vegas, that way you'll see the preview shown as it will export to tape. i tested it on cs4 and it works perfectly to export the correct size and with no black borders on a canon hv30.--
CS3 HDV Export to tape marathon/firewire nightmare
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 2nd Aug 2010, 11:34 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
Premiere Pro CS3 HDV export
By kippard in forum EditingReplies: 0Last Post: 12th Oct 2008, 20:30 -
Premiere Pro CS3 export
By kippard in forum MacReplies: 0Last Post: 11th Oct 2008, 19:33 -
Premiere Pro CS3 EXPORT PROBLEM...
By REiGN in forum EditingReplies: 2Last Post: 25th Feb 2008, 18:30
