Hey.
I am new at this stuff and i need to know if i can record with my pioneer dvd recorder, an av channel from my tv? I wanna plug in a gaming console and record it through the av channel. I dont want to plug the gaming console straight into the recorder coz it is slow and not resposive on the console. It lags. So i wanna be able to play it through the tv while recording so i can watch the av channel with no lag rather than the dvd recording channel thing with lag. Thanks for any help.
	Does your TV have a video out port ? Most older TVs have multiple inputs, but very few have video out. I am surprised that the recorder would produce such a lag on your console.
 Depending on the type of connection, you might be better off getting a simple cable splitter and running one side through to the TV, and the other through to the recorder.Read my blog here.
	No my tv only has audio out. I was looking at splitters but i just seeing if there is a way without buying anything. Thats why i just wondering if i can record the av channel on the tv. The lag isnt that bad, it is like tiny bit but you can tell the difference. Thanks
	I'm not sure what you're asking, but if you're asking if you can record RF from your gaming console while running A/V cables directly to your TV the answer would be yes if your game console has RF out and your Pioneer has a tuner that can tune that RF channel.
 You'd get better quality feeding your DVDR with line outputs(from your game) but if your game only has one video line output you'd need a amplified video splitter, which may incur even more lags. You can split audio with a simple Y cable, but if you do that with video your picture will suffer(mostly be darker). That's why you'd need a video amplifier to overcome the loss.
  DVD Recorder will only record when TV is switched onBy jiminwatford in forum DVD & Blu-ray RecordersReplies: 23Last Post: 18th Apr 2011, 15:03
  DVD Recorder does not recognize anything above Channel 36By Marianne777 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Jan 2010, 16:11
  Is it possible to record a channel you cannot watch?By showmi in forum DVD & Blu-ray RecordersReplies: 11Last Post: 7th Sep 2008, 01:13
  any way to record from TV to DVD recorder?By thedriver2200 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 10th Jun 2008, 13:37
  Watch one channel, Record AnotherBy NYWino in forum Newbie / General discussionsReplies: 12Last Post: 10th Jul 2007, 16:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
