Results 1 to 13 of 13
    Jul 2006
    I have what appears to be a very high quality HD video clip which Premiere Pro CS 2 or 3 cannot play.
    Maybe I need another codec on my Vista machine.
    All options are open, however I'm asking you gents what's the best way by using this forums tools to:
    Convert the .mov HD file to a .avi file (at comparable quality) for playback & further processing purposes on the PC .
    Yes, Quicktime for the PC plays it but not much else.
    I tried to convert it but the results were not good at all.
    Here's the file specs as I know them:
    24 bit/pixel depth, 48k audio, 1280 x720, 60i (59+ frames per second) HD Quicktime file in .mov format.
    What would really be helpful & appreciated is to know not only what the best solution is, but what the settings and parameters are for those apps or programs as well.
    Thanks!
    mp4camtoavi might work. Or mpeg streamclip, try different video codecs, less compressed better quality.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Use mediainfo in Tree mode to determine exactly what you have.
    Read my blog here.
    Jul 2006
    It turns out the file is (from what I can figure out) Apple ProRes 422/"lossless".
    Not necessarily PC friendly as I discovered.
    Codec is apch or something like that.
  5. install the windows prores decoder, and you should be able to use it directly in PP (works in CS4, not sure about earlier versions)
    http://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Windows
    EDIT: jagabo beat me
    Yes, it works with avisynth's QTInput() , but it works through quicktime API, so any application that can access that can use it. e.g. mpegstreamclip , premiere pro, vegas
    Jul 2006
    General
    Complete name : C:\Video Ministry Promo Spots NEW\01_Promo 1.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 309 MiB
    Duration : 15s 31ms
    Overall bit rate : 172 Mbps
    Encoded date : UTC 2009-05-07 13:30:21
    Tagged date : UTC 2009-05-07 13:35:57
    Writing library : Apple QuickTime
    Media/UUID : 89DAB078-F377-4618-B0E6-915C47CBF705
    Video
    Format : ProRes
    Codec ID : apch
    Codec ID/Hint : HQ
    Duration : 15s 31ms
    Bit rate mode : Variable
    Bit rate : 170 Mbps
    Width : 1280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 59.940 fps
    Bits/(Pixel*Frame) : 3.079
    Stream size : 305 MiB (99%)
    Language : English
    Tagged date : UTC 2009-05-07 13:30:30
    Audio
    Format : PCM
    Format settings, Endianness : Big
    Format settings, Sign : Unsigned
    Codec ID : in24
    Duration : 15s 31ms
    Bit rate mode : Constant
    Bit rate : 2304 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 24 bits
    Stream size : 4.13 MiB (1%)
    Language : English
    Menu
    Language : English
    Encoded date : UTC 2009-05-07 13:30:30
    Jul 2006
    I tried to upload a screenshot but have no idea where it went!
    Maybe the admin needs to approve it first?
    I do not have CS-4.
    Avisynth is Greek to me. Do not understand it or how it works.
    My goals are as follows:
    1) To convert this to a more PC friendly format at comparative quality.
    2) So that CS2 plays it from the timeline.
    Is MPEG Streamclip my only viable option, and if so, what are the settings I should set the parameters too?
  8. it should work anyways, directly in PP all versions, if you have the prores decoder installed with quicktime
    it's quite sluggish on PC, because decoding of .mov container not optimized on PC. Prores on a MAC flies - as if you were editing DV
    if your pc specs listed are correct, there is nothing that will give you similar quality and yet good playback performance for editing (everything will feel sluggish), you would need a faster computer
    Jul 2006
    Hi,
    I'm not sure what you mean by "sluggish". I was reffering to the visual quality when played back without jaggies, artifacts and other types of digital garbage being present (& newly introduced by the conversion process) in the image/video.
    If we now take the next step beyond just playing it in it's current format, hopefully by converting it to a .avi, reasonable quality will be preserved. I do not have QT Pro or the MPEG-2 encoder.
    I hope someone will kindly pass on all of the MPEG Streamclip settings in detail in order to obtain the optimum result, the best solution available at this time.
    Thanks for you valued replies.
    Jul 2006
    Doesn't having QT installed means that other tools found in this forum do not function properly?
    QT Alternative is reccomended in at least one, I just can't think of the apps name at the moment.
  11. No, QT can co-exist with basically everything , it uses a different systeam than other decoders
    Apparently the newest release 7.6.6 released yesterday is causing havok and problems, so I would try an earlier version if you can
    Not sure if it will work with QT alternative, but it works with QT pro
    Try it out. I have CS2 installed in one of my older computers , but you could just as easily test it out , it should only take a few seconds
    Cineform would be the equivalent where you have near lossless quality, and good decoding performance, but it's not free, and you would need at least a dual core for it to work properly
    Jul 2006
    Thanks for the heads up on QT 7.6.6 issues which I already downloaded but did not install yet.
    I'll find an earlier version and see what happens.
