I'm surprised how many hit that mark. I think I've ripped about 30 discs so far and most are at around 40gb. Is it uncompressed audio?
Partly the reason; you often have more tracks (either lossless or uncompressed audio in mulitple languages), more extras, because the studios can stuff extra things in with the extra capacity
But the max video bitrate for blu-ray spec is higher @ 40Mbps compared to HD-DVD which is ~29Mbps - this doesn't mean the studios always max out on video bitrate, far from it - but it means they could use higher bitrate if then wanted to -
Not to mention that HD-DVD's almost always are VC-1 encoded vs blurays which do come in h264 more often.
An interesting read for context.
http://blogs.zdnet.com/Ou/?p=959
Some typical Blu-Ray bit rates
http://forum.blu-ray.com/blu-ray-movies-north-america/3338-blu-ray-movie-bitrates-here.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
BluRays not playing right on N1
By x22 in forum Blu-ray RippingReplies: 4Last Post: 16th Oct 2011, 15:43 -
Few n00b questions regarding backing up blurays ..
By ahmadka in forum Blu-ray RippingReplies: 0Last Post: 20th Apr 2011, 12:49 -
What do you use to play Blurays?
By Dexx in forum Software PlayingReplies: 9Last Post: 24th Jan 2011, 17:27 -
is there an easy way to get trailers off of my blurays?
By AndyD in forum Blu-ray RippingReplies: 4Last Post: 18th Dec 2010, 12:57 -
can you rip blurays and then remove audio commentaries without reencoding?
By krohm in forum Blu-ray RippingReplies: 2Last Post: 1st Mar 2010, 09:54
