    Mar 2010
    Boston
    Hi, I've got a 1 minute trailer that I need to burn to a very high quality. My file is 3GB. When I try to burn the file in Toast, it compresses it to something much much smaller. I want to keep it looking very good. Please help. Thank you.
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    What kind of video? (MKV? MP4? MOV?) And, is it HD video? More information (use the OS X version of MediaInfo, for example) might help.
    If you're creating a DVD-Video disc (supposed to be compatible with most DVD players), your video will be re-encoded to MPEG2 with a maximum resolution of 720 x 576 (PAL) or 720 x 480 (NTSC). See What Is: DVD at the top left corner of this page for more information.
    Mar 2010
    Boston
    Okay, thanks. My video is not HD. It is a quicktime, though not marked MOV. I exported straight from my Final Cut timeline, no compression, as the video is only 1 minute long.
    The end product needs to be compatible with most DVD players, yes. It is NTSC 720 * 480.
    Mar 2010
    Boston
    Looking to create a really high quality DVD. So far, I cannot find a way to compress my video into MGEG 2 without losing a crap load of size and quality. Please help.
