    Nov 2003
    Anaheim, Ca.
    Anyone know Cubase enough to help with this.?
    I just installed CB LE4 and interfaced with a Zoom H4n recorder, after recording two stereo track I want to mix down.
    Going to File/Export/Audio Mixdown I get this message Need String Here! You need to set the locators!
    WHAT? the heck, I looked it up in the manual on line and support with no avail.
    Can anyone help or at least turn me in the right direction.?
    Much Appreciated
    GT
    "You have not because you ask not"
    James 4:3
    Jul 2009
    Spain
    You need to set the left and right locators to define the start and end points of the section to export.
    To export the entire recording, set left locator to the start and right locator to the end of the recording.
    Nov 2003
    Anaheim, Ca.
    Thank you "Gavino" I appreciate the help. I have found the locator buttons and it works just fine.
    GT
    James 4:3
