Hi,
I'm doing avi to svcd conversion with TMPG using the 2pass VBR mode giving 300kbit min and 2536kbit max bitrate. The average bitrate calculation is done with FitCD. I'm doing only video conversion no audio.
In most cases there is no problem, after muxing the video it will fit exactly on a cd, but sometimes I get files with about 100MB to much size.
The calculated bitrate is O.K. I even tried other calculators, but its still the same effect.
Is there a possible solution for my problem ?
I must admit that I am quite new to TMPG because I was using CCE in earlier times, since it began crashing on my new new hardware.
Thanks for your help,
Piff
Results 1 to 1 of 1
Mpg : Mpeg video size and bitrate calculation
By Bonie81 in forum ProgrammingReplies: 2Last Post: 21st Jun 2011, 22:38 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 19:01 -
Need some info on bitrate calculation
By heman28 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 18:18 -
video bitrate calculation
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 21:30 -
Newbie needs bitrate calculation advice to convert my 1st PAL to NTSC
By queen_anne in forum Video ConversionReplies: 35Last Post: 20th May 2007, 21:48
