Hi,
I have a Samsung HT-X250 DVD player. Some time ago I successfully entered the multi-region hack that is mention on this website. I know need to know is there anyway of reversing it? Any DVD now entered says "incorrect region" Can someone please help me, I just want to restore the factory default region of region 4.
The player may be going bad. In the future my advice to you would be to NOT buy Samsung players. Samsung DVD and BluRay players are among the most difficult in the world to make region free. Sony are also very difficult to make region free. You are just asking for problems in trying to make those players region free.
I looked at the hack and it's impossible for me to say with certainty how to undo it. A guess is that if you replace the final digit (9) with the desired region (I guess that's 4 for you) and enter that code, it might do the job. Or it might not. It could do nothing or even make things worse.
I've heard of region 1 discs that don't behave correctly on region free players due to RCE, but a region 4 DVD should not result in an "incorrect region" message on a region free player. This is why I think your player is simply going bad. It happens. Today's DVD players are rarely built with quality components and they are basically expendable. If you get more than a few years out of them, you've done well. Many consumers don't know this, but today's DVD players need to be kept in places with a lot of open air so they can air cool. Many people keep their players in home entertainment centers that have closed walls and are actually quite bad for the players. Heat damage is inevitable over time. -
Thanks for your reply. Yeah I tried replacing the (9) with a (4) before I posted the thread with no such luck. The machine will play older region 4 discs, just not new ones.
Multi Region Hack for Sharp DV-sl1200w
By gilljaz in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Jun 2009, 04:00 -
Multi Region Hack for Soniq QPD120B
By hammertime in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Mar 2009, 12:00 -
Multi Region hack for a Pioneer DVR-LX70D
By llatrel in forum DVD & Blu-ray RecordersReplies: 0Last Post: 26th Feb 2008, 14:03 -
help on region hack Philips DVD963SA from German to US/Multi region
By stieven in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Jul 2007, 12:29 -
LG DNX190UH-NEED A MULTI-REGION HACK PLEASE
By vonbek14 in forum DVD & Blu-ray PlayersReplies: 19Last Post: 18th Jun 2007, 15:54
