I like the idea of using tsmuxer in linux. However, when I try to create blu-ray content , i get the error:
Unsupported media type 15 for AVCHD/Blu-ray muxing
It creates data that I burned to a disk (bd5 on dvd+rw), but my blu-ray player would not acknowledge it as a valid disk.
I have looked on the internet but cannot find any help.
Any suggestions?
And is there a linux application that authors blu-ray content for dvd disks with menus? I have some small home movie clips in high def I wish to preserve to disk.
Which version of tsMuxeR? Have you tried the newest one? Are you dealing with AAC audio? I see the error is mentioned here: http://forum.doom9.org/archive/index.php/t-134104-p-14.html The post is on: April 27th 2009, 16:22
I am using 1.10.6. Yes, the video is 1920x1080x30p, h264 and aac. I am experimenting, but if you can suggest some things I can try, I would greatly appreciate it. I heard that an older version would work with aac. Do you know where I can get an old version I can try?
I found an older version (I am running linux) and it would not load my video files. I went back to the current version, loaded the video file, unchecked the aac audio, imported an mp3 (and later mp2) audio file, attempted to make the blu-ray files and it errorred as well but with a media type of 4 (for mp3 and mp2 audio). The last statement in the output window is "Creation of Blu-ray playlist". Any thoughts? Here is the output:
SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
Decoding H264 stream (track 1): Profile: Baseline@4.0 Resolution: 1920:1080p Frame rate: 29.97
H.264 stream does not contain fps field. Muxing fps=29.97
H264 bitstream changed: insert nal unit delimiters
H264 bitstream changed: insert pict timing and buffering period SEI units
Decoding MPEG-Audio stream (track 2): Bitrate: 128Kbps Sample Rate: 48KHz Channels: 2 Layer: 2
H264 bitstream changed: insert SPS/PPS units
Processed 9303 video frames
Question: where is the output for the blu-ray disk content to be? I am using a harddrive folder to later burn to a dvd-rw. Is this correct?
Ripping Blu-Ray with TSMuxer or TsRemuXer
By privateapples in forum Blu-ray RippingReplies: 36Last Post: 10th Sep 2012, 04:41 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Blu-ray + DTS-HD authoring with tsMuxeR
By Zerrax in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Nov 2011, 19:30 -
tsMuxer Blu-ray outputting, audio delay?
By dabezt in forum Authoring (Blu-ray)Replies: 0Last Post: 25th Apr 2011, 05:35 -
No subtitles when using tsMuxeR 1.10.6 to convert mkv to Blu-ray
By mistercool in forum Authoring (Blu-ray)Replies: 14Last Post: 20th Mar 2010, 14:28
