Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 13 of 13
  1. Member brassplyer's Avatar
    Apr 2008
    Is there an app that allows you to record DVD's in real time using a standard DVD burner? I.e. not capturing then rendering but just going directly to DVD. Ideally an app that would take DV input from firewire via my Dig8 camcorder.
    Apr 2004
    Miskatonic U
    I believe VideoStudio used to offer something along these lines, and a few of the cheapo USB capture toys offer it. You need a CPU fast enough to do the encoding in real time (single pass only) or a capture card that has mpeg-2 hardware assist. And you can't use your PC for anything else while it is recording.
    Read my blog here.
    No -- they all worked like crap. Get a DVD recorder for realtime work.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    An MPEG2 capture card is as close as your gonna get I'm afraid.
    Feb 2004
    Australia
    Yes ulead videostudio but the interface was as much as drain ... nero reloaded was far better with less interface lag for direct to disc. Of course going from dv to disc wouldnt be much fun due to the amount of space required so there has to be some form of compression taking place.
    The avermedia dvd ezymaker pci delux supports direct to disc provided system meets or exceeds system requirements.
  6. Originally Posted by lordsmurf View Post
    You mean: Yes -- they all work(ed) like crap.
  7. Sonic MyDVD use to have the ability but I haven't used it in years, I think they call it Direct-To-Disc.
  8. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    get a recorder....all else is just a waste
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
  9. Member yoda313's Avatar
    Jun 2004
    The Animus
    The pinnacle usb dongle has the direct to disc recording you are looking for. I think hauppauge is the main player now in usb models however. I would check their website for manuals on whether or not they also have direct to disc recording.
  10. Member brassplyer's Avatar
    Apr 2008
    Hmm...the name "Pinnacle" doesn't fill me with confidence. Any personal experience using it?
  11. Originally Posted by brassplyer View Post
    As was stated:
  12. Maybe LiquidTV?
    Sounds like you want to build your own PVR. There is a website for that byopvr.com
  13. Member brassplyer's Avatar
    Apr 2008
    Originally Posted by handyguy View Post
    Maybe LiquidTV?
    Not necessarily, though it seems lnteresting. Just exploring to see if there was an app to do it as I find there often is when I get a notion to do something.
