I have a video which is mp4 and the audio is .aac but I cannot demux or open with any program
Is their software that would demux the audio or convert aac to wav?
MEDIAINFO
General
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 828 MiB
Duration : 1h 37mn
Overall bit rate : 1 189 Kbps
Writing application : ZJMEDIA MP4/3GP/MOV Encoder v1.0
Comment : QuickTime 6.0 or greater
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 1h 37mn
Bit rate mode : Constant
Bit rate : 1 025 Kbps
Nominal bit rate : 512 Kbps
Width : 704 pixels
Height : 368 pixels
Display aspect ratio : 1.913
Frame rate mode : Constant
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.158
Stream size : 714 MiB (86%)
Writing library : ZJMedia MPEG Encoder
Language : English
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 37mn
Bit rate : 160 Kbps
Nominal bit rate : 80.0 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 111 MiB (13%)
Language : English
You can't have tried too many programs, or the file must be completely fubar. I suspect the former.
VLC - if it can play it, it can transcode it.
Xvid4PSP
Any Video Converter Free
AVI Demux should be able to demux the audio, and the latest Audacity beta with ffmpeg should be able to load and convert the resultsRead my blog here.
Thanks for the help Guns1inger and Calidore, but the programs that you mentioned seemed to have a problem with the audio
But I was able to encode the audio with TMPGenc Xpress and it worked fine!
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 22:59 -
Cannot convert ADTS AAC file to anything
By Killer3737 in forum AudioReplies: 2Last Post: 17th Jul 2011, 20:08 -
Losslessly convert AAC file to MP3?
By sldvd in forum AudioReplies: 16Last Post: 17th Nov 2010, 07:04 -
I want to demux an .mp4 file and convert to a microsoft dv .avi file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2009, 22:42 -
Demux DVB-S HD H264/AAC HE
By erbipjr in forum DVB / IPTVReplies: 3Last Post: 3rd Sep 2009, 15:48
