Hope someone can help me with this...
I've hacked a couple of DVD players using instructions from this site...looking to hack yet another.
The instruction for the hack of my Panasonic DMP-BD60 starts with: "I used a Kameleon 8 URC-8308 "
What is this Kameleon?
Thanks!
Caryna
It's a universal 8 device remote control: http://www.audiovisualonline.co.uk/dynamic/eshop_products.set/ref/1212/one-for-all-kam...8/display.html That may be a European only version. But the company seems to sell some models through Radio Shack.
And welcome to our forums.
Thank you!!
So, I take it that without this remote, I cannot hack my new player? No other hacks were listed for this particular model. -
If your guide is correct, it probably would take that remote or similar to hack that player.
But you might want to read that guide further and other remotes may work.
I think redwudz is right that you can probably use another model of remote. A lot of those URC hacks depend on the so-called "magic button" (setup) function. You can get a lot more info on that here:
http://www.hifi-remote.com/ofa/faq.shtml#1.7
It's a very old page and there's probably more up-to-date info out there, but I haven't kept up with it.
Section 1.9, about the advanced codes, is probably the capability that you need. -
I have a Panasonic DMP-BD605K (US model) & I see that it may be possible to hack unit. Is there an American Universal Remote that could be used, if so which one. I recently made a Region Free disc from a Region 2 PAL disc. Eventhough the disc I made is Region Free, the unit will not play it.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Applying kameleon 6 URC-8206 instructions in a OneFor All URC-8820
By garciamaki in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Jul 2010, 11:01 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
