I am trying to do some night infra red work with a Sony DCR-TRV33E to monitor animal behaviors at night. I want to know if I can either reprogram the camera to make a video at a very slow frame rate , say 5 frames a minute, or take a photo to the memory stick at the same rate. Is this possible? Can I reprogram the camera??
I am really struggling to get this work done so if enay one has any ideas they would be greatly appreciated,
Regards
Craig
Wrong forum. This is only for Latest Video News. Moving you.
And, goodnature, in the future please use a more descriptive title so others can find your posts. I will change yours this time.
Moderator redwudz -
Unless your cam already has a timelapse feature, it would be very unlikely. For the memory stick, you can do it via LANC but need specific electronics to do so.
Depending on the logistics, you might consider connecting your cam to a laptop via FireWire and use capture software that can do timelapse (see signature) - make sure there's no tape in the cam though otherwise it will switch off after a short while. I did something similar with the cam on a tripod outside (a clear night, no rain forecast!), a long FireWire cable and a laptop on the front porch.John Miller
Sony Handycam DCR-HC53E -- help!
By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jun 2010, 17:52 -
Slow Frame Rate
By tobymac in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 10th Mar 2008, 13:12 -
Slow Read Rate
By mr240 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2008, 17:41 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
