I have some AVC video that was captured with a GoPro HD Hero camera. I would like to make the following edits to the raw footage:
- trim undesirable video
- add transitions
- add a 2nd audio track
Is it possible to do these edits without re-encoding? If so, using what program(s)? Below is some info on the video.
Format : MPEG-4
Format profile : JVT
Codec ID : avc1
File size : 584 MiB
Duration : 10mn 2s
Overall bit rate : 8 134 Kbps
Encoded date : UTC 2010-03-14 12:49:38
Tagged date : UTC 2010-03-14 12:49:38
AMBA :
Video
Format : AVC
Codec ID : avc1
Duration : 10mn 2s
Bit rate mode : Variable
Bit rate : 7 999 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Bits/(Pixel*Frame) : 0.290
Stream size : 574 MiB (98%)
Title : Ambarella AVC
Language : English
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 10mn 2s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Stream size : 9.19 MiB (2%)
Title : Ambarella AAC
Language : English
VideoRedo's new beta does trims of HD AVC material without re-encoding. It won't do transitions, and even if a smart-encoder comes along that does more than VideoRedo, transitions will have to be re-encoded (anything that changes the actual video requires re-encoding).
AVIDemux might also be able to handle your files - it handles most AVC files - and will do trimming and can add audio tracks without re-encoding. Again, no transitions though.Read my blog here.
Only a suggestion to join all your clips and cut/trim losslessly: MPEG Streamclip I use it every day for clips from my Kodak Zx1 (which I notice has a much higher bitrate than the GoPro HD Hero, typically 13mbps).
Michael
phototools.co.nr
AVC HD re-encoding to burn to DVD - need help
By Quaker2001 in forum Video ConversionReplies: 3Last Post: 19th Oct 2010, 17:56 -
How to edit MP4 with AVC video and AAC audio?
By nonexistent_entity in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2009, 07:58 -
edit video hd avc 1080p
By miss in forum EditingReplies: 2Last Post: 20th Jul 2009, 11:21 -
Edit MPEG2 video without encoding
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Feb 2009, 14:05 -
MP4 AVC/H.264 encoding
By Jacobus Serpenti in forum Video ConversionReplies: 17Last Post: 1st Jan 2009, 09:18
