Here is a short videoclip (24 secs). I compressed it with divx (hq) to keep a lower filesize, hope you don't mind.
It has been captured with a usb-capture card.
Results 31 to 36 of 36
Apart from the saturation (and that may be OK in other places), I'd be happy putting this onto DVD as-is without any tweaking at all.
If you want to tweak, try something like...
...or the VirtualDub equivalent.Code:avisource("example VHS.avi") assumetff() # increase colour saturation: tweak(sat=1.3,coring=false) # make it a little sharper horizontally: sharpen(0.5,0) # crop out the junk: crop(16,0,0,-20) # put clean borders in to bring back to DVD resolution: addborders(0,8,0,12) #histogram(mode="levels") #bob()
Uncomment the histogram line to check the levels (they're fine).
Uncomment the bob line to see it deinterlaced (badly) (don't do this for DVD).
Check the saturation on other parts of the video. 1.3 is probably too much. If so, try 1.2 or 1.1.
Drop the above .avs file into an MPEG encoder to generate something ready for DVD.
(Obviously work from your master copy, not your DivX encode)
A TBC in the VCR would probably make the image look a little more stable, especially at the top. Alternatively, forget the capture card: a good DVD recorder would probably include a TBC, and increase the saturation by default, making any external processing almost redundant.
If you want more tweaking, try VirtualDub deshaker to fix the slightly shaky camerawork.
Hope this helps.
Cheers,
David. -
The black level needs to come down. ColorYUV(off_y=-12) or thereabouts. You might be able to restore some detail in the blown out areas if you adjust the levels before any RGB conversion.
Also, look into Neat Video for noise reduction in VirtualDub.Last edited by jagabo; 9th Apr 2010 at 12:00.
Thank you for your suggestions.
I was experimenting with Neatvideo in virtualdub, however it's quite slow on my pc.
With filters for contrast (the build in level filter) and saturation (color mill) and sharpening (msu smart-sharpen) it processes arroun 9-10 fps.
When i add neat-video it goes down to 0.80 fps.
My pc might be getting old, and i don't mind it taking a few hours, but 0.80 fps is just to slow. -
With a big filter chain that includes NeatVideo, I get about 2-3fps on a quadcore.
My last encode was about 56 hours.Want my help? Ask here! (not via PM!)
I don't think I'd bother with Neat Video on the clip you posted - it's hardly noisy.
I assume things shot in low light are far noisier though?
Cheers,
David.
Specific Panasonic VCR buying advice needed
By Sainsbo_McManus in forum RestorationReplies: 8Last Post: 28th Nov 2011, 20:30 -
JVC S800U worth buying for VHS restoration/conversion
By mark23 in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2008, 12:22 -
Professional Video Restoration VS buying my own Hardware. (VHS/BETA to DV)
By HOTPROPHET in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2008, 12:47 -
Equipment purchasing for largescale restoration and archiving project.
By MorlockMan in forum RestorationReplies: 47Last Post: 27th Nov 2007, 11:30 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02
