So I have this video file with no file extension. we'll say it's called "title. " now the problem i'm having is that it is only 15 minutes long and 4.5 GB in size, with no audio. I was going to convert it to mp4 to put it on my ipod, but my video converter can't tell what kind of video it is, & so the converted video comes out as garbage. how do i determine what the proper file extension is?![]()
thanks now i know it's an avi, sadly that didn't fix my underlying problem of when i try to convert the video to mp4 it either turns out garbage or it plays at double speed altering the duration to 6m01s instead of 15m20s.
You might try Any Video Converter Free Version. I've had good luck with it with some odd formats. I assume you probably already added the .avi extension to it, though that may not help. Or it may be that you just have a badly corrupted file.
How do you know the proper duration is 15m20s ?
Have you successfully played the file in a media player? if so , which ones?
Is there supposed to be audio?
What does gspot say about the file?
Did you try renaming the extension ".avi"
Can you post the mediainfo report , (view=>text) copy & paste the report back
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 16:52 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
very strange divx file with mystery fourcc
By cooldude859 in forum Newbie / General discussionsReplies: 13Last Post: 9th Apr 2009, 21:00 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
