Hello,
Im Searching Freeware Programs for DVD-AVCHD Authoring.
I Remuxed the Video Files with TsRemux, and now I Need à Programm(or 2) to add à Menü and Burn it all on DVD-AVCHD.
I will Not Juse à usual DVD because My Movies are HD Movies and I will keep this.
If someone Know à Programm wich can do this and is for free please post it.
The only One I Found is multyAVCHD
THANKS YOU FOR YOUR HELP
and sorry for My Bad english
Multi-AVCHD is probably the best option for menus etc at the moment.
AVCHDCoder is faster if you need to re-encode, but the menu options are simpler.
TSMuxer is fine if you don't need menus.Read my blog here.
And can One of this programs burn it on DVD?
Because I have no Programm where I can set the needed settings (UDF)
or did you Know some other Freeware Program for Burning wich can this?
I Know no Freeware Programm for this, just Nero, Corel... And they cost up to 50�,
and I Need it just for Burning
burning avchd files to blueray
By alphonso49uk in forum Authoring (Blu-ray)Replies: 5Last Post: 24th Mar 2012, 16:12 -
Possible tool from jdobbs for blueray to dvd5/9 avchd backup.
By freebird73717 in forum Blu-ray RippingReplies: 12Last Post: 30th Sep 2008, 03:18 -
WinDVD 9 Plus BlueRay will not play m2ts AVCHD files
By deejay.2001 in forum Software PlayingReplies: 2Last Post: 14th Jul 2008, 09:33 -
Put severeal AVCHD Mini-Disc onto a DVD-5: How?
By gekko_video in forum Authoring (Blu-ray)Replies: 4Last Post: 14th Apr 2008, 16:35 -
Computer reports mini dvd 8cm as blank. Sony HDR-ux7. Recorded in AVCHD.
By conan48 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Sep 2007, 19:19
