  1. Member Ogilvy's Avatar
    Jul 2005
    Germany
    Hi, in extracting audio from DVD using VirtualDubMod do I have to do this on a VOB- by-VOB basis?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    DVDDecrypter is much easier if your DVD is not "ganz neu".
    IFO Mode
    Stream Processing
    Enable Stream Processing
    Un-check the video stream
    Check audio stream
    Select your destination
    GO
    You can also set DVDDecrypter to give you one, giant piece of audio
    or set it to give you "chapters" - individual songs from a concert DVD.
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I don't know if you're really running Linux, but if you can run PGCDemux, that is a better choice to demux audio (as AC3), combining however many VOBs as necessary.
  4. Member Ogilvy's Avatar
    Jul 2005
    Germany
    Thank you both for such a fast reply, think I'll try dvd Decrypter first...then comes Linux alternative as I'm on a dual-boot system
