I have a macbook with OS X (10.5). I followed these instructions:
HOW TO MAKE A DVD WITH SELECTABLE SUBTITLES ON MAC OSX WITH FFMPEGX. I tried to convert/burn a DVD from an AVI file. I selected "DVD mpeg2enc". I skipped the subtitle step, although I'd like to use it in the future. I burnt with disc utility.
The result was a DVD with blank video and garbled audio. The files created by the program before burning were the same. The AVI file plays fine on my computer.
Suggestions?
	Ok, instead of "DVD mpeg2enc" I selected "DVD ffmpeg" and it worked. The DVD plays just fine on VLC. But in my macbook's DVD player the video is "choppy" - freezes every few seconds. Also, the audio is out of sync with the video (I'm away from home, and can't try it out on an external DVD player) Any suggestions?
	Before burning, test playback in Apple DVD Player (Menu File > Open > Select VIDEO_TS folder; press Play in the console). Playback on your set top player will likely be the same. This test will save you from wasting discs.
 "Choppy video". This is most likely a symptom of missing "3:2 pulldown" on 23.976 fps framerate DVDs. Use mpeg2enc and check the "Set 3:2" checkbox in the Options tab, to add the soft pulldown to the video.
 "Blank video". This is a symptom of being unable to decode the video in the AVI with current settings.
 For best advice, please tell a bit more about the AVI. What is the video codec? What is the video framerate? What is the audio codec (e.g. mp3)? What is the sample frequency (e.g. 44.1 kHz, 48 kHz)?
  ffmpegX and/or Toast 8 - Loss of video quality in converting to DVDBy bonespur in forum MacReplies: 2Last Post: 9th Mar 2011, 02:52
  Converting MKV to AVI using ffmpegXBy Vitoarc in forum ffmpegX general discussionReplies: 4Last Post: 13th Aug 2010, 11:51
  No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad EverythingBy koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48
  .AVI is not properly converting to .FL when using ffmpegXBy - Ø®£Z - in forum MacReplies: 9Last Post: 27th Jul 2007, 17:07
  Converting an AVI video with AC3 audio to an AVI video with MP3 audioBy rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
