  1. I've just ripped "The Crimson Rivers", everything fine except that I've got the original language of french. On the DVD it's dubbed to english.
    Could somebody please point me in the right direction so that I can extract "english" sound from the DVD when I do the rip.
    Using
    Smartripper
    DVD2AVI
    Tmpgenc
    ChapterXtractor
    VCDEasy.
    Any help would be much appreciated.
    Cheers
    Chris.
  2. select the audio track in dvd2avi under audio/track number/#. smartripper stream processing tab will help you identify the one you want(first audio stream is track 1). not that i mind answering such a simple question again, but it should be noted this question is easily answered by searching the forums, not to mention more in-depth responses than this one
  3. Thanks for your help Stan.
    I tried a search, but couldn't find the right phrase to use to try and find an answer to my problem.
    Also checked all the relevant guides with no luck.
    All I have to do now is figure out which is the track I need for the audio.
    Cheers
    Chris.
