H folks --
Sorry for the beginner question, but I've authored quite a few DVDs from an avi file with menus using TMPG, but it occurs to me that in some cases it would be better if the user could just put the DVD in their player and have the video just begin, with no menuing whatsoever.
I've never done this before -- is it possible? Can someone point me to a walk-through? I did a little Google searching but it was hard to sift this particular need from all the DVD-related menu discussions.
Thanks for any help!
-- Dave
whatever you use for dvd authoring should be able to set it to play the movie first. check the help files for first play or movie only.
Encore DVD Menu Authoring
By montgal in forum Authoring (VCD/SVCD)Replies: 4Last Post: 30th Apr 2012, 00:24 -
DVD menu software to import into TMPGEnc Authoring Works 4
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 28th May 2010, 14:34 -
how to keep original menu and not re-encode files by dvd authoring
By deejay.2001 in forum Authoring (DVD)Replies: 8Last Post: 1st Sep 2008, 03:08 -
dvd authoring with hidden menu
By VeryNewbie in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2007, 04:21 -
DVD Authoring: Menu Creation, Encoding, etc
By kerpal in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 19:27
