The software came with Happauge HD-PVR. Suddenly, I have 4 coasters in succession. The errors occurred at around 70-80% of the burn.
I have less than 4GB to put in. The Optiarc DVD writer can still write successfully using another program. I have created about 10 DVD-AVCHD before. I do not know where to begin. I have version 2. I'm hoping somebody migh have experienced this problem and has the solution. Thanks.
I am using leftover Verbatims and using Total Media Extreme AVCHD writer. I am trying to compile some HD materials from TV using DVD media which is playable in Blu-Ray. Perhaps my next step is to reinstall the software. Thanks.
Cannot open .mov files in Total Media Extreme
By edong in forum Authoring (Blu-ray)Replies: 5Last Post: 16th Jan 2012, 22:18 -
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 14:46 -
Does arcsoft total extreme have a 3 hr maximum limit for authoring?solved??
By yoda313 in forum Authoring (Blu-ray)Replies: 0Last Post: 11th Mar 2011, 12:41 -
Total Media Extreme Audio De-Sync Problem
By www1221 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 18:35 -
just can't cut it with total media extreme
By romanticwarrior in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Mar 2009, 03:24
