Hi - I just bought a Kodak zi8 HD mini camcorder. It saves files in H.264. I have a mac and want to use Final Cut Express. I know I need to convert the files to another format for FCE to edit.
I read an article about converting in MPEG Streamclip exporting as Quicktime/Apple Intermediate Codec at 100% quality. This worked GREAT (very fast too) for movies that didn't have much movement. Then I tried it with a movie I shot from a moving car and the resulting converted footage was VERY choppy.
I shot the movie clip on 720/60fps setting. Has anyone any ideas on what I can do or what setting in Streamclip will help and will retain max quality. Or is there any OTHER way to convert H.264 720/60fps clips for FCE. Thanks.
Hi - don't worry I found the answer. Open the H.264 clip in MPEG Streamclip. Edit>fix timecode breaks - File>Export to Other Formats. choose Quicktime Movie - then Options - Apple Intermediate Codec - Settings - frame rate 59.94 - HDV 720p. then click Adjustments in the final window if you want to edit the clip in any way. and that's it - SMOOTH video!
convert h.264 to use in Final Cut Express. Streamclip problem
By robinhall in forum Video ConversionReplies: 2Last Post: 28th Mar 2010, 16:54 -
MPEG Streamclip, Final Cut Pro 6 and a DVD
By BovineofWar in forum DVD RippingReplies: 0Last Post: 28th Aug 2009, 11:47 -
With a mac how do I convert a Final Cut Express item to mpeg2 dvd?
By dagardenguy in forum ffmpegX general discussionReplies: 2Last Post: 16th Jan 2009, 13:00 -
Final Cut Express help
By dpoon in forum MacReplies: 11Last Post: 6th Feb 2008, 16:12 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05
