Has anyone captured from a laserdisc source and made into a VCD? What were the results? What's the quality like?
Just wondering because my laserdisc player is about to give out. Would it really be worth archiving my favorite out-of-print titles that aren't on DVD?
Any feedback greatly appreciated.
i use to have a sony mdp333 player ( 12inch cd )
result a very good with direst Svcd (AiW-radeon)
depend of the original track on the disk -
I have done about 50 laser disk captures, I capture at 640x480 using either huffuv or picvideo compression ( no noticalbe difference), the result will not as good as a dvd rip is pretty darn close, better than a vhs copy of the laser disk.
I have made several captures from laserdisc to SVCD with very good results. The only bad feature is most movies take 3 discs and some 4.
I've been using virtualdub with picvideo plug-in & tmpeg encoder. If you use the best settings in tmpeg encoder, quality is very good, but it takes a long time to encode.
Anybody know how to get the AC3 track onto SVCD so a DVD player can play it back?
Capture laserdisc audio (s/pdif to PC)
By digitalfreaknyc in forum AudioReplies: 13Last Post: 5th Aug 2010, 10:49 -
Laserdisc to DVD capture questions
By bmwracer in forum Capturing and VCRReplies: 3Last Post: 8th Mar 2010, 12:04 -
Laserdisc: Blade Runner
By vhelp in forum Off topicReplies: 11Last Post: 2nd Aug 2008, 00:19 -
LaserDisc to DVD!
By hellhole in forum Video ConversionReplies: 4Last Post: 1st Oct 2007, 03:07 -
LaserDisc to DVD with TmpgEnc Xpress 4.0
By sapulidi in forum RestorationReplies: 5Last Post: 16th May 2007, 13:42
