I encoded an .avi (23.976 fps, progressive) with Tmpgenc to .mpeg as (23.976 fps, progressive)
And converted my .wav to .ac3 using EncWAVtoAC3 but when I muxed using Tmpgenc and play they are out of sync.
I dont understand why it happened if I didnt change the fps on the video?
Is their a way to avoid this when encoding?
Or if this happens can I use some program to adjust to sync issue thanks
Thanks Baldrick
But I just notice that when I demux the audio with virtualdubmod it loses more than 2 seconds in time.
What i would like to know is if theirs any program that add some time to the audio file?
To fix the sync issue thanks
Sync issues after muxing AVI files
By FatalX in forum EditingReplies: 0Last Post: 23rd Dec 2009, 21:33 -
encoding analog tv recording - sync issues
By barcode02 in forum Video ConversionReplies: 0Last Post: 12th Aug 2009, 04:51 -
Higher bitrate encoding causes audio sync issues
By keiron in forum Video ConversionReplies: 3Last Post: 12th Jun 2008, 05:37 -
I am Legend Encoding (Blu-ray) audio sync issues
By Ansuer in forum Blu-ray RippingReplies: 21Last Post: 1st May 2008, 18:54 -
Sync issues with encoding for DVD or Web
By sfischer in forum MacReplies: 2Last Post: 26th Dec 2007, 20:01
