BD Rebuilder, full backup, playing on a PS3.
If there is a 00000.BDJO file in the BDJO folder, I can't backup successfuly to BD5/9. BD-25 will backup just fine, though.
Is there a way around this? It will happily write the disc, but the disc won't play in the PS3. I've used several versions of AVCHD patcher (for non-BDJO file discs, I use 1.06, and if it doesn't modify the index file, I'll run 1.04, and this has worked out well). If you do movie-only backup, it will work fine with a BD5/9, but I prefer full disc backups.
I've done some Google searching, and this got me no where but figuring out my initial problem with the BDJO files.
JO = Java Object.
The disc has a complex BD-J java menu. Movie-only works, as you've found, but you may not be able to get full disc on BD 5/9 to play on your PS-3. Does the disc have any PIP tracks? Perhaps a disc released by Universal, by any chance? There has also been in the past some suspicion as to whether BDRB updates java menus correctly in the rebuild phase for *some* discs. The fact that a BD25 works would however tend to discount those possibilities.
Does the BD 5/9 backup play in another AVCHD-capable standalone player?
1) You could try AVCHDCoder to eliminate BDRB as a cause.
2) What is the firmware of your PS-3? I hesitate to recommend updating it, as I don't have one and don't know much about them.
3) You could try ripping again with BD-Live disabled. Then run it through BDRB again.
Good luck.
Pull! Bang! Darn! -
- I have ripped with BD Live enabled and disabled, makes no difference
- PS3 has the most current firmware
- I don't know anyone with a stand-alone Blu-ray player; everyone I know runs a PS3, which IMO is the way to go (I do a lot of video streaming with it as well, plus a little bit of gaming).
- I'll have to look into AVCHDCoder. Newegg selling Ridata 15 cake pack BD-R's that end up averaging out to $2.13/disc, so it's not the end of the world to burn to BD-25, but when I am paid .08/disc for a DVD -R, and not a lot for DVD +R DL, there is a money factor involved. Anything where quality is a real concern, I go BD-R anyway.
Is there any recent/uptodate list for bd players that play bd5 bd9 bdr/re?
By fjmr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Jul 2010, 07:36 -
Looking for a program BDShrink (like DVDShrink) for BD to BD5 (DVD-R) Conv.
By Bonie81 in forum Blu-ray RippingReplies: 4Last Post: 30th Jun 2010, 17:01 -
Powerdvd won't play movie with an empty BDJO subfolder in the BDMV folder
By gll99 in forum Software PlayingReplies: 0Last Post: 29th Oct 2009, 21:29 -
BD5 problems with converted files
By briansxx1 in forum Blu-ray RippingReplies: 1Last Post: 14th May 2009, 08:20 -
AVCHD vs BD5/BD9?
By Randm in forum Newbie / General discussionsReplies: 9Last Post: 10th May 2009, 07:41
