Im sure this has been posted before, but I have a UK macbook on snow leopard, and i have a region 1 dvd, yes i have 5 changes left on the dvd player, but is there any way i can avoid changing it. On windows there were programs like DVD43. Is there an alternative for the mac
Harry
I have not seen any such software for mac. You could try upgrade/flash the dvd drive firmware, see http://forum.rpc1.org/viewforum.php?f=30 and it should be region free. Play with VLC.
Or rip the dvd with mactheripper and play it. -
There is a program for the Mac called Region X, which would allow you to change the region setting as many times as you wanted. I used this on my old G5 tower and never had a problem with it. Better yet go for an external for the "foreign" DVD's, as mentioned above.
Tom -
Originally Posted by jman98If cameras add ten pounds, why would people want to eat them?
"Region X will allow you to change the region Apple DVD Player is set to, when and only when you play a movie from a region-free DVD drive."
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
Ripping Region 2 discs on Mac pro
By jabbo5150 in forum MacReplies: 6Last Post: 22nd Feb 2009, 11:46 -
Problem with Region settings
By paulgold in forum DVD RippingReplies: 11Last Post: 18th Apr 2008, 21:47 -
Region settings help
By ian curtis in forum Software PlayingReplies: 6Last Post: 7th Dec 2007, 07:19 -
Changing the internal PIONEER DVD-RW DVR-109 Drive's Region Settings
By vidmarc in forum MacReplies: 5Last Post: 4th May 2007, 08:48
