For example, you have a HDTV version of an episode, and there's only DVDRip subtitle for it in your language.
When there is already HDTV subtitle in English.
All what I need to do is to sync the Arabic DVDRip subtitle to the English HDTV subtitle.
How to sync Arabic subtitle to match English subtitle since they both have the same number of lines?
Any program can just copy text from line1 in Arabic sub and paste it in line1 in English without changing its timing??
	Coz knowledge is everything... left ;)
 http://mriddler.blogspot.com
	Subtitle Workshop can do this with Roman fonts, don't know if it can with Arabic.
	I use Subtitle Workshop4 beta 4. First I open english sutitles, then I open Edit menue-Timings-Adjust-Adjust-Subtitles(or Ctrl+B). In opened window you see time when first and last subtitle start. Then I open estonian subtitles in Subtitle Workshop and change (Crtl+B)first and last subtitle start time similar to english ones. But always you need to be sure that first and last subtitles in both languages are same. For example sometimes estonian subtitles begins with the name of movie. Then before adjusting I delite first row.
	An easier way (at least in version 2.51):
 Open the sub with the correct text.
 "Edit/Timings/Adjust/Adjust to synchronized subtitles" and select the sub with the correct times.
 As above, make sure that the first and last subs really do correspond.
	Thank you very much for your reply, I already know this one.
 It goes in details like this
 1) File => Load Subtitle / Ctrl+O
 And then open the file to be modified, which is Arabic one
 2) Edit => Timings => Adjust => Adjust Subtitles... / Ctrl+B
 And Copy first and last timings from the English correct file.
 3) File => Save / Ctrl+SCoz knowledge is everything... left ;)
	Yes, It works fine if for example estonian and english subtitles have same number of rows and they mutch one by one. I've used this method only once because estonian internet subtiles have often different numer of rows. And it's because most of them are translated by hearing, not by english text subtitles.
  An app to visually sync audio to video similar to Subtitle Edit visual syncBy cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54
  Subtitle Workshop - not creating subtitle at current time locationBy botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 04:09
  Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 12:25
  Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 18:03
  Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 15:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
