I have been searching for a while, and haven't found this problem listed, so I thought I would ask.
Mods may delete this if I just overlooked it, and apologies in advance.
I have the DVP3982-37, Region 1, USA model, no modifications or hacks or upgrades from Philips.
It plays fine, except for long AVI's.
It seems that an AVI over 1 hour, 30 minutes will just stop around the 1:45:00 mark, or maybe make it to 1:51:00.
It seems to happen only with ISO MPEG4 XVID files, according to GSpot, with PVOP and VBOP.
The file plays fine on the PC, but when burnt to a DVD (several media names), the Philips only plays it for the above amount of time, then just stops and goes back to the menu. None of the files are over 1.4 GIG in size.
Other shorter files (~700 MB but all less than 1.5 hours) on DVD or CD-R play just fine.
I am at a loss to figure this out, and would appreciate any advice.
Thank you.
BKN
  desperate help needed with Philips DVP3982By DaneClark in forum DVD & Blu-ray PlayersReplies: 3Last Post: 2nd Jul 2010, 23:56
  Philips 5982 & 624x352 AVI Playback ProblemBy gonwk in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2010, 16:20
  Philips DVP3982 IssueBy nickolasj80 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Jun 2009, 14:37
  Premiere 6.5 - Playback stops after 20 minutes on NEW PC.By Phase52009 in forum EditingReplies: 0Last Post: 29th Jan 2009, 19:55
  Philips DVP5980/12 is freesing during AVI playbackBy webshield in forum DVD & Blu-ray PlayersReplies: 9Last Post: 6th Apr 2008, 01:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
