I am trying to figure out the best way to transfer to DVD and at the same time Capture on PC while utilizing the proc amp and the detail-er for both inputs... I understand that I can burn a DVD from my computer but for time purposes I would need to do both at the same time. My current setup is JVC HR-9600U or Panny AG-1980 to TBC-1000 to BVP-4 Proc Amp to DR-100 detail-er to Panasonic EZ28 DVD recorder. Would taking the Monitor out from the TV to the capture card be a good idea?
I would experiment but I don't own a capture card or software yet. Another possible scenario would be putting the TBC-1000 at the end of the string since it has a built in distribution amplifier, or does having the TBC at the end of the string effect the quality of the video? I do have a S-Video Distribution amp but it is a Radio Shack model and it can add a little noise to the picture. If there is a program out there that can convert DVD files to a high quality uncompressed video file that may even be a better bet.
Also I am new to using software for video restoration, I hear alot about virtual dub... would that be my best bet? I work with Avid editors and they seem to only give me advice based on using an Avid or FCP system which wouldn't suit my needs. I believe Avid is out of the Prosumer business anyways, and I don't own a Mac. I should note that my computer is running Win 7 64 bit. I feel like my 2nd question has been answered in older threads, but I was more curious as to whether in 2010 there is a new software that has an edge on virtual dub, free or for purchase.
You may want to look in the restoration forum - many of your questions (including the process train) have been asked/answered by the experts. I could put in my 2 cents, but you'd only receive a margin of the knowledge available on this site.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Thanks for the heads up, I am new to the forum. I will take my question over there.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
VHS to DVD to PC capture?
By NYC Film in forum RestorationReplies: 0Last Post: 29th Mar 2010, 13:25 -
Which of these two capture cards are better for VHS to DVD?
By nomad2224 in forum Capturing and VCRReplies: 14Last Post: 23rd Sep 2009, 09:05 -
About to capture VHS to DVD
By Nightshiver in forum Capturing and VCRReplies: 14Last Post: 10th Jan 2008, 20:22
