I have a 1-3 copier using an acard controller,,it recently just keeps saying target drive not ready each time i try and copy..i have swapped the ide leads and used a different master and it still says the same,,im guessing my controller is duff now after all these years,,any thoughts peeps?
I have a 1 to 3 Acard, had a one-to-one with HD image backup before.
1. Different discs - same result (i.e. new disc after getting message)?
2. Different drive - same result.
Check the size of the original disc - if it's a dual layer, the Acard definitely will NOT attempt to burn, because it'll be searching for 8.5 DL media and a drive that it can burn too - of which it cannot.
If the original is Cd and you're burning to DVD = NO GO - or the other way also.
Never forget Acard's tech support - even if you're out of warranty, you can read your way through the forums to find an answer.
If none of the above works, mail me the Acard card - maybe I can get it working.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Hi thanks for your reply
the discs im burning are data discs that were blank initially and have been written
I have burnt the same stuff before and the same discs before so its unusual to be honest
Ive tried different discs to burn and still get the same result
I really am thinking its the controller
I am going to take it to pieces later and then maybe come back to you
Thanks for your help
Acard DVD Duplicator Error Message
By JJ1958 in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Oct 2015, 16:45 -
acard dvd duplicator
By johnthedog in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2010, 14:43 -
DVD duplicator help?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 12th Sep 2009, 10:46 -
dvd Duplicator
By kingnat2 in forum DVD RippingReplies: 3Last Post: 28th Jul 2007, 08:49 -
NG:01 error w/ Acard Copysmart Plus duplicator controller
By Bix in forum DVD & Blu-ray WritersReplies: 2Last Post: 15th Jun 2007, 22:38
