I know I am not going to gain any quality, but my DVD player doesn't support SVCD, so I want to convert and author as a DVD compliant file. Is this possible? I've tried just loading the mpg file from the SVCD into TMPG but it said that it is unsupported. The file plays OK in Power DVD.
you could try www.vcdhelp.com/vcddvdr.htm
but the best is to convert to compliant dvd format www.vcdhelp.com/mpeg2tovcd.htm (load the dvd template instead of vcd).
and last author www.vcdhelp.com/burnmpg.htm#dvd
how to convert dvd to other format
By steelmaster in forum Video ConversionReplies: 2Last Post: 27th Apr 2012, 14:26 -
How to convert DVD to AMV format ?
By pchan in forum DVD RippingReplies: 5Last Post: 13th Dec 2011, 08:42 -
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
Convert FLV to DVD format
By PowerFalcon in forum Video ConversionReplies: 2Last Post: 13th Dec 2009, 19:31 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
