Hi! Im about to order a Pioneer BD-R writer and would like to start authoring Blu Ray,
Ive been using DVD Lab Pro for DVDs for a while now, is there something similar?
Also I will be using MPEG 2 format for the Blu Rays, since I have some series I would
like to transfer from DVD to Blu Ray. Thanks!
Thread: Need good BD Authoring software
TMPGEnc Authoring Works does MPEG2 Blu-ray. What's your budget for new software?
Years ago I used DVD Lab Pro too. It's very good for DVD authoring. But now I use Sony DVD Archidect 5.0 for my Blu Ray authoring. It is bundeled with Sony Vegas Pro 9.0 : http://www.sonycreativesoftware.com/vegaspro
Hi I see that "TMPGEnc Authoring Works" reencodes the MPG2, is there any other program that does not re-renders
the MPG2's when authoring?
thanks -
bump, anyone? Im still looking for one hehe thanks
Not much. You could investigate some of our BD authoring programs. Maybe multiAVCHD for BD if you are looking for freeware. Some of the other BD authoring programs are a bit pricey. But you could look here: https://www.videohelp.com/tools/sections/authoring-bd-hd-dvd
It may help if you described your end goal. Full Blu-Ray authoring is pricey and not targeted to consumers.
http://www.kiva.org/about
Which authoring software has good motion wedding menus?
By sterankin in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2010, 04:21 -
A good dvd authoring program?
By t_jay17 in forum Authoring (DVD)Replies: 3Last Post: 31st Mar 2010, 21:50 -
Looking for a good authoring software that support using MP4 files to DVD
By LegendaryGamer in forum Authoring (DVD)Replies: 4Last Post: 10th Mar 2010, 16:04 -
What's a good dvd authoring program to use?
By zanos in forum Authoring (DVD)Replies: 14Last Post: 3rd Mar 2008, 11:11 -
What is a good authoring tool?
By breeze9 in forum Authoring (DVD)Replies: 1Last Post: 26th Jan 2008, 00:17
