I have found verification of Blu-ray BD-RE discs in AVS Video Editor very very slow indeed.
Has anyone experienced this and overcome the problem some way - e.g. got the verification to speed up?
AVS's solution (when they finally got in touch, support slow) is to download a "driver package" to "help the burner recognise the BD structure".
But they don't say anything more about this, simply advising "search the web for the driver package"...and..."Nero has a driver package built in".
I've asked AVS to tell me how they test their software and what burner and "driver package" they use.
My setup is a Windows 7 64bit home premium Quad-core intel i7 1.6-2.8Ghz (fast) 4gb, Nvidia, 7200rpm HP laptop with a LG BE06 LU10 USB 2.0 external Blu-ray burner recorder. I believe this is way beyond adequate to achieve acceptable verification speeds, the actual writing is fast enough - to the maximum 2x for the BD-RE Verbatim media I am using. I've seen the slow verification problem on Windows XP machines also.
LG's support site has no mention of this "driver package".
If AVS are suggesting Nero has this driver package then I might as well create a Blu-ray disc image in AVS Video Editor and burn this in Nero - but then you'd ask why do AVS offer Blu-ray burning if the subsequent verification is very slow.
In general, reading/copying files via Windows Explorer from BD-Rom discs is no problem and is an acceptable transfer speed so why is verification so slow?
Any thoughts?
Results 1 to 1 of 1
AVCHD/"Blu-ray" fails to play on Sony X Box. Should it?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 9Last Post: 24th Aug 2010, 18:34 -
DVDFab "Blu-ray to Blu-ray expired"
By Teutatis in forum Blu-ray RippingReplies: 15Last Post: 8th Jan 2010, 23:16 -
Ripping Blu-ray Movie "BULLITT" Audio Problems
By titot4u in forum Blu-ray RippingReplies: 1Last Post: 16th Nov 2009, 10:22 -
Should Sony change the name to "blue-ray" instead of blu-ray
By yoda313 in forum Off topicReplies: 11Last Post: 17th Feb 2009, 13:52 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08
