hi people this is my first post on here as im new
my problem is that i have a hd lcd tv the make is (murphy)
and im try to get my sorround system to play the sound coming from my xbox360
the connections on my surround are...a red and white l/r audio cables
i have bought a switch box for my tv and switvhed it to output and plugged the 2 cables into it but the sound still plays from the tv
and i could of simply connected the 3.5mm jack straight into my tv but there isnt a hole for it
i want to continue using my hd cable also
tanx hope i made it easy to understand
Describe or illustrate exactly how you are set up.
It sounds like you have the HDMI connected directly to the television. If so, that is the sound output also.
It also seems that you do not have an HDMI pass-thru on your surround amp.
Depending on your 360 and amp, you may be able to connect through the S/PDIF cable.
I haven't hooked up a 360 in years, so I'm not sure of the menu settings and configuring output. -
yes my hdmi from the xbox is connceted to my tv directly
ive now fix it
thanks anyway though..
i found a great tutorial out of luck
its for people who want to use a surround system with their xbox360 but have no 3.55mm on there tv.
so what i did was as shown on the this link here
http://www.chadledford.com/?p=50
then plugged the red and white from my surround into the scart
so i can use hdmi as video and scart as sound its working perfectly
Great! I always forget about SCART. I also forget to look at location sometimes. That would have helped.
Cannot find DV output pin
By RalphW in forum Capturing and VCRReplies: 11Last Post: 23rd Jan 2024, 16:14 -
iMovie output to anything, no sound
By rikyo in forum ffmpegX general discussionReplies: 2Last Post: 6th Jan 2010, 09:13 -
How to find moive sound effects?
By squeejiboo in forum Off topicReplies: 2Last Post: 29th Aug 2008, 08:04 -
HDMI sound output from TV
By chronicnight in forum DVB / IPTVReplies: 5Last Post: 31st Dec 2007, 21:25 -
Does this output sound right in VD?
By php111 in forum Newbie / General discussionsReplies: 0Last Post: 6th Oct 2007, 17:00
