Hi there, first post indeed.
I've been using Premiere Pro for some time now.
However, I've noticed that whenever I create a new project (of any settings), whatever I export will freeze upon watching. I'll get perhaps 3-4 seconds of video, then a frozen picture and whatever playback application I'm using will struggle.
Has anyone else experienced this, or have any kind of idea what's wrong?
I still have a project (that I created long ago) that this won't happen to, and so am stuck using the same project over and over!
CPU, RAM, hard drives ??
--- usually this means you don't have enough resources available.Want my help? Ask here! (not via PM!)
Never been an issue before.
As I say, I have a project set up and anything I export from that - whether it be thirty seconds or ten minutes long - works absolutely fine.
It's any new project/project settings. -
It sounds like the programme has become corrupt some where.
Back up your video and project file.
Uninstall it and do a registry clean. Reinstall it. That usually will work.
Report back.
Setting up Premier Pro Projects correctly-Scratch Disks
By Downing32 in forum EditingReplies: 0Last Post: 8th Jun 2010, 10:03 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Random freeze or stop while exporting to tape in Premiere Pro CS4
By LghtAndDrk in forum EditingReplies: 1Last Post: 8th Jul 2009, 00:51 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 16:27
