I have plenty of memory, 6GB. Everything is closed. Vegas is the only thing really using any memory.
I've been rendering 720p video for the past couple of weeks fine, but now today it won't. I have a quad core CPU as well, even though that shouldn't be the problem.
I'm using Vegas Pro 32bit on Windows 7 64bit.
	I've never seen that warning in Vegas, but in other programs it translates to disk space including the tmp disk which absorbs huge decompressions.
 You shouldn't have the tmp file disk (Adobe calls this the swap file) on the C: drive anyway but it is easy to forget which drive is recording your tmp files.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	I've experienced this issue before as well when trying to render 1080p files with my Vegas Pro 9. One workaround was to click on "network render" (even though you are using only one computer). To the best of my knowledge, this is how I was able to get around the problem, but it has been several months since I've seen it. I found a thread on creativecow months ago through a google search. If I can find the post, I'll link to it.
	Here is a newer link to a similar problem:
 http://forums.creativecow.net/thread/24/906211
	One of the suggestions by someone was to render using Network rendering although there is only one computer I will use.
 Also will it make a difference if I render to my RAID 0 array that's 1% full as opposed to the OS drive which is about 70% full that I was already rendering to?
  Issues with low memory while rendering Vegas 11By magic612 in forum EditingReplies: 28Last Post: 8th Dec 2011, 20:49
  Low cpu usage decoder+render for netbook...By elmuz in forum Newbie / General discussionsReplies: 5Last Post: 30th Jun 2011, 06:34
  Vegas 8 - "System low on memory. You may be able to reduce memory usagBy sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16
  virtual memory too low?By deadman1972 in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2009, 10:22
  Sony Vegas 8 low memory errorBy mouseclubhouse in forum EditingReplies: 13Last Post: 7th Aug 2008, 18:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
