I currently use Ulead Dvd MovieFactory but it takes so long to load!
Although the output quality is very good
What do you use?
How is the output quality?
Results 1 to 11 of 11
I said the output quality is good, because I have used Authoring software that messes up the quality.manono Re: I need new Dvd Authoring software ?
The output quality is good? What are you looking for, an encoder or an authoring program? Those are 2 different things, you know? Me, I usually author using Muxman. The output quality is the same as what I feed into it in the first place.
And yes i know what your talking about sorry for not being specific
Are you happy with Muxman? How long have you been using it for?
If you have used ones that messed up the quality, then they have been reencoding your video.
I love Muxman. I've been using it for years. It doesn't create menus, though. It only authors from elementary streams. When I want to make menus, I create them myself and use DVDAuthorGUI to author. Both of the ones I've mentioned are freeware. Lots of people here will recommend DVDLab Pro or TMPGEnc Authoring Works as good commercial authoring programs. -
I use DVD Lab Pro and it is the bomb.
Very easy to use, great output, very good control over menus, auto chaptering, multiple subtitle streams etc.
As mentioned earlier though, I never use it for re-encoding.
Built in encoders are often slow and not that great.
Encode first to DVD quality using your encoder of choice (I often use TMPGEnc, lately I have been using ConvertXtoDVD when I get lazy and dragging the vobs into DVD Lab Pro to give them a nicer menu) then use your authoring program to do what it's best at doing: authoring! -
Use Ulead DVD Workshop 2. I wrote about this last week: Is DVDWS2 best for authoring?
- Guide for using DVDWS is here: http://www.digitalfaq.com/forum/showthread.php/author-ulead-dvd-1506.html
- Buy it for the current low price of $49 at http://www.bhphotovideo.com/c/product/311318-REG/Corel_Ulead_A25420111_DVD_Workshop_2....3167/KBID/4166
Thanks everyone!
Well I tried using muxman but it doesn't show the video file I am trying to use.
It works fine with other .m2v file and my .ac3 but certain video files wont open so Thanks you anyways muxman
Ill see If I can Purchase Dvd Lab Pro and give it a try.
I also have Tmpgenc Authoring Works so ill have to go back to it
Then your video file isn't DVD compliant for one reason or another. If you want to cut off a piece and upload it for us to have a look, we might be able to tell you why it wasn't accepted. Or, you might check the Muxman log (in the root of the C drive) to see if there's a more detailed explanation. That might be why some of the authoring programs you use messes up the quality. It's being reencoded to make it compliant.
Don't blame Muxman for your own incompetence. -
B&H did another price drop. DVDWS2 is now just $24.95. Unbelievable!
Buy it while it's available.Want my help? Ask here! (not via PM!)
dvd authoring software
By devdev in forum MacReplies: 2Last Post: 20th Apr 2012, 04:36 -
DVD Authoring Software
By Toxic1 in forum Authoring (DVD)Replies: 5Last Post: 21st Feb 2010, 02:39 -
By rancineb in forum Authoring (DVD)Replies: 8Last Post: 9th Jul 2008, 14:11 -
best DVD authoring software??
By yunakokimama in forum Authoring (DVD)Replies: 3Last Post: 20th Dec 2007, 15:38 -
Best DVD Authoring Software
By mai_hnf in forum Authoring (DVD)Replies: 3Last Post: 30th Sep 2007, 11:25
