With .srt subs and Xvid/Divx video, they just need to be in the same folder as the video and the player should find them. That would be burned as a data disc.
With a regular DVD, they are part of the VOBs and are added in while authoring to the DVD format.
And welcome to our forums.
yeah hi,I'm trying to burn them as data(for a mac or p.c.)I have an intel mac osx.Should i even be using toast or should i use the utility disc.I also don't know how to create a folder with the subs attached to the movie file.Please excuse my ignorance..and thanks again for you're.Cheers help
Create a folder on your MAC, place the video file and the subs inside the folder (they have to be named the same thing ie movie.avi movie.sub) and then burn the folder making sure you recorder software is set to close or finalise disc.
thank you ,I'll do that.thanks for taking the time to help me.I'll let you know how it works out..Burke
attaching logitech sub to m-audio monitors
By gooberguy in forum AudioReplies: 0Last Post: 4th Sep 2010, 14:53 -
Attaching mp3 to video without converting?
By xtube in forum Newbie / General discussionsReplies: 4Last Post: 10th Aug 2010, 10:49 -
Basic Question about Attaching / Syncing Subtitles
By Seeker47 in forum EditingReplies: 2Last Post: 12th Dec 2009, 14:05 -
Attaching an mp3 to a video without compression.
By Racoon29 in forum Newbie / General discussionsReplies: 13Last Post: 25th Jul 2009, 13:41 -
Attaching a Mac External HD to a PC to copy
By phase52001 in forum MacReplies: 6Last Post: 21st Jul 2009, 04:49
