Hello there,
Very new to the DVD authoring thing here. I've found that AVStoDVD is a great program, but without much video expertise I'm consistently at a loss on how to get it to work. Thanks to people on this forum and the creator of the program, I've gotten some help. But the latest issue I find is the inability to make .iso's for some projects. AVStoDVD seems to fail at the muxing stage. Here are the log files. Can anyone tell me what I'm doing wrong here? Thanks.
Mordum + Penance_0.txt -
<3/25/2010 9:13:12 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 2
DVD Size: 4408/4450 MB (99%)
DVD Output Setup: ISO UDF Image
DVD Label: Mordum + Penance
DVD Menu: Static Menu
Output Folder: C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: A2DSource
AVS Resize Filter: Lanczos4Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6000
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliat Audio: 1
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: EN - English
Chapthers Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D:\
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\T Trilogy\T Mordum.mpeg
Info: MPEG-2 Video - 4573 kbps - 720x480 - DAR 1.5 - 29.97 fps (CFR) - Progressive - 47:11 minutes - 84847 frames
Audio: C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\T Trilogy\T Mordum.mpeg
Info: AC3 - 448 kbps - CBR - 48000Hz - 2ch - 47:10 minutes
Subs:
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
# Video is frameserved by AviSynth just for Preview and Edit purposes.
Video = A2DVideoSource("C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\T Trilogy\T Mordum.mpeg", CacheFolder = "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\T Trilogy\T Mordum.mpeg", CacheFolder = "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp")
Video = Video.ConvertToYV12
Video = Video.AddBorders(0,30,0,30)
Video = Video.Lanczos4Resize(720,480)
Audio = Audio.Normalize()
Audio = Audio.DelayAudio(-2.3)
AudioDub(Video, Audio)
START VIDEO DEMUXING OPERATIONS
Target Video FileSize: 1543.3 MB
FFmpeg Parameters: -i "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\T Trilogy\T Mordum.mpeg" -vcodec copy "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_01_T Mordum.m2v"
<3/25/2010 9:14:53 PM>
END VIDEO ENCODING OPERATIONS
Created File: C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_01_T Mordum.m2v (1495.3 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 4465 kbps - 720x480 - DAR 1.5 - 29.97 fps (CFR) - Progressive - 47:08 minutes - 84762 frames
<3/25/2010 9:14:54 PM>
START AUDIO ENCODING OPERATIONS
Wavi+Aften Parameters: "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Title_01_T Mordum.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_01_T Mordum.ac3"
<3/25/2010 9:17:23 PM>
END AUDIO ENCODING OPERATIONS
A2DAudioSource: DirectShowSource
Created File: C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_01_T Mordum.ac3 (151.1 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 48000Hz - 2ch - 47:08 minutes
TITLE 2 SOURCE FILES
Video: C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\T Trilogy\T Penance.mpeg
Info: MPEG-2 Video - 3821 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 1:24:55 hours - 152717 frames
Audio: C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\T Trilogy\T Penance.mpeg
Info: AC3 - 448 kbps - CBR - 48000Hz - 2ch - 1:24:55 hours
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\T Trilogy\T Penance.mpeg", CacheFolder = "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\T Trilogy\T Penance.mpeg", CacheFolder = "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp")
<3/25/2010 9:17:24 PM>
Target Video FileSize: 2321.2 MB
FFmpeg Parameters: -i "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\T Trilogy\T Penance.mpeg" -vcodec copy "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_02_T Penance.m2v"
<3/25/2010 9:19:40 PM>
Created File: C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_02_T Penance.m2v (2243.6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3721 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 1:24:50 hours - 152564 frames
Wavi+Aften Parameters: "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Title_02_T Penance.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_02_T Penance.ac3"
<3/25/2010 9:22:40 PM>
Created File: C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_02_T Penance.ac3 (272 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 48000Hz - 2ch - 1:24:53 hours
<3/25/2010 9:22:41 PM>
START DVD MENU BUILDING OPERATIONS
DVD Menu settings: Style 0, DAR 1, Titles Format 1, Video BitRate 9000, Menu Pages 1, Menu Titles 2
<3/25/2010 9:22:57 PM>
END DVD MENU BUILDING OPERATIONS
Created File (Menu Page 1): C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_MenuPage1.bmp (2.5 MB)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_BatchMux.ini"
BatchMux ini file:
-d "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0\VIDEO_TS"
-mxp "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_MuxMan.mxp"
-l "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_01_T Mordum.m2v"
-vidmode 4:3
-a1 "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_01_T Mordum.ac3"
-a1lang en
-cellfr "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Title_01_T Mordum_MuxMan.txt"
-progfr "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Title_01_T Mordum_MuxMan.txt"
-chapfr "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Title_01_T Mordum_MuxMan.txt"
-SEG2v "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_02_T Penance.m2v"
-SEG2vidmode LB
-SEG2a1 "C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_02_T Penance.ac3"
-SEG2a1lang en
-SEG2cellfr "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Title_02_T Penance_MuxMan.txt"
-SEG2progfr "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Title_02_T Penance_MuxMan.txt"
-SEG2chapfr "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Title_02_T Penance_MuxMan.txt"
-SEG3v "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_MenuPage1.bmp"
-SEG3vidmode LB
-SEG3s1 "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Menu.sst"
-SEG3s1dmode WIDE_LB
-SEG3hlmnu "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_MenuPage1_Buttons.mnu"
-SEG3hlcsm "C:\Program Files\AVStoDVD\Menu\Highlight_Scheme.csm"
-hcn "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_BatchMux.hcn"
<3/25/2010 9:23:09 PM>
PROCESS ABORTED DURING DVD AUTHORING OPERATIONS!
CHECK FOLLOWING FILES FOR MORE DETAILS:
AVSTODVD LOG FILE <C:\DOCUMENTS AND SETTINGS\DJ HAZ-MAT\MY DOCUMENTS\MY VIDEOS\MORDUM + PENANCE_0.LOG>
BATCHMUX LOG FILE <C:\DOCUMENTS AND SETTINGS\DJ HAZ-MAT\MY DOCUMENTS\MY VIDEOS\MORDUM + PENANCE_0_BATCHMUX.LOG>
<3/25/2010 9:23:12 PM>
Log file created by AVStoDVD Release 2.2.6
Mordum + Penance_0_BatchMux.txt
BatchMux version --> 1.3
Destination Folder --> C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0\VIDEO_TS
MuxMan Script File --> C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_MuxMan.mxp
MuxMan Log String --> -l "C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_MuxMan.log"
Folder of the MuxMan executable --> C:\Program Files\AVStoDVD\MuxMan
Check presence of MuxMan.exe --> PASSED
Segment #1 - Video File #1 --> C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_01_T Mordum.m2v
Checking asset for importing as --> M2V, M1V, MPV
Video Coding Mode --> MPEG-2
Video Resolution (Nominal) --> (720x480)
WARNING - MPEG-2 Aspect Ratio Code 1 not allowed for DVD
Video Frame Rate --> 29,97 fps
Video Bitrate (Nominal, Kbps) --> 8789
VBV Buffer Size (Kbyte) --> 224
Segment #1 - Video Display Mode --> 4:3
Segment #1 - Audio #1 File #1 --> C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_01_T Mordum.ac3
Segment #1 - Audio Lang Code #1 --> en
Segment #1 - Timeframe file --> C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Title_01_T Mordum_MuxMan.txt
Segment #1 - Total Nr of Cells --> 10
Segment #1 - Total Nr of Programs --> 10
Segment #1 - Total Nr of Chapters --> 10
Segment #2 - Video File #1 --> C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_02_T Penance.m2v
MPEG-2 Aspect Ratio (DAR) --> 16:9
Segment #2 - Video Display Mode --> LB
Segment #2 - Audio #1 File #1 --> C:\Documents and Settings\DJ Haz-Mat\My Documents\My Videos\Mordum + Penance_0_Title_02_T Penance.ac3
Segment #2 - Audio Lang Code #1 --> en
Segment #2 - Timeframe file --> C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_Title_02_T Penance_MuxMan.txt
Segment #2 - Total Nr of Cells --> 17
Segment #2 - Total Nr of Programs --> 17
Segment #2 - Total Nr of Chapters --> 17
Segment #3 - Video File #1 --> C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_MenuPage1.bmp
Checking asset for importing as --> BMP
Image size --> (928x80)
Segment memory resources --> RELEASED
Local Stack memory --> RELEASED
File i/o structures --> DEALLOCATED
It may not have anything to do with it, but in this title, 'Mordum + Penance_0_Title_01_T Mordum.m2v' the '+' symbol seems a bad idea. I usually avoid mathmatical symbols, along with gramatical symbols like / - , . ? :, etc., in titles.
But someone else here may spot something more in the log. -
There is one 'real' warning:
MuxMan is quite picky about the compliance with the DVD spec. You can try to use DVDPatcher or similar to correct the aspect ratio.
See here:
http://dvd.sourceforge.net/dvdinfo/mpeghdrs.html#seq
Only Aspect Ratio Code 2 or 3 is allowed for DVDGUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
There are 2 issues
1.
You should force AVStoDVD to re-encode title 1 because it has a DAR of 1.5, instead of 1.333 or 1.778. Next AVStoDVD release will check also DAR to verify DVD video compliance. Thanks borax for the clarification.<3/25/2010 9:13:12 PM>
2.
The Menu background file C:\DOCUME~1\DJHAZ-~1\LOCALS~1\Temp\Mordum + Penance_0_MenuPage1.bmp is NOT a DVD bckg file but a AviSynth error output picture (size 928x80).
BTW, KKPHM, you should have received the same warning when you were creating the DVD Menu, shouldn't you?
redwuk may have hit the point: using special chars is always a pain.
Rename your input file, force title 1 re-encoding (or use DVDPatcher to correct DAR), re-build your project and then retry.
Bye
AVStoDVD - Quantizer..?
By VenusAndMars in forum Authoring (DVD)Replies: 16Last Post: 15th Jun 2012, 08:59 -
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 21:37 -
AVStoDVD
By Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 08:29 -
AVStoDVD!
By Milardo in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2009, 06:01 -
Fairuse Wizard issues: Bad video and muxing failure.
By octick in forum DVD RippingReplies: 2Last Post: 28th Apr 2008, 16:51
