Is anyone able to play a Mini DVD on Mustek V520? I'm using Ulead DVD Movie Factory and I have a file longer than 2 minutes as suggest by other posters. When I play the disc, I get the following display on the TV:
Play mode: Folder
I see the following files:
Root
TS_Video
TS_Audio
What should I do to get the normal DVD play mode and not the folder mode?
Helpful hints will be truely appreciated.
Ove
Same problem in my case:
I've got a Yukai v520 (a Mustek's clone) and when I try to play a miniDVD it goes to folder mode. In fact you can play the VOB if you select it in the video_ts folder and change the audio channel to C0.
I can also play any raw MPEG2 file in folder mode. I play VCD but not with PBC options (Photo Album from WinOnCD doesn't work). I don't play SVCD neither ...
PS: My player has the ESS VideoDrive chipset and not the WinBond chipset included in the v520IV.
Joan
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 10:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 18:27 -
Firmware for Mustek DVD Recorder R100A
By Spot.Zwei in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th Jan 2011, 10:49 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18 -
Mustek V56L-5E DVD player How To Reboot remove YUV P-Scan setting
By ImNoSmarterN5thGrdr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Aug 2007, 09:32
