Closed Thread
    Dec 2009
    I cant see what is wrong with this conversion of a MKV file.
    The process just freezes and I have to delete the processes in order to try something different.
    Can anybody see what is wrong? The file plays fine with VLC.
    When I press the start button, AVCtoDVD vanishes from the screen. I can see QUuEnc.exe running in the process queue. After about a minute the process turns red and says "not responding". Then two popups show as seen below.
    Whats wrong?
    <3/24/2010 7:41:28 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 1
    DVD Size: 4450/4450 MB (100%)
    DVD Output Setup: DVD Folder
    DVD Label: UP 2009
    DVD Menu: No Menu
    Output Folder: C:\Temp\Azureus_DLs
    Delete Temp Process Files: Yes
    Delete Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    AVS Source Filter: A2DSource
    AVS Resize Filter: Spline16Resize
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 5000
    Video Profile Level 2: 4000
    Video BitRate Max: 9000
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    DVD Audio Format: 0
    DVD Audio BitRate: 96
    Keep DVD Compliat Audio: 1
    Normalize Audio: 1
    DVD Audio Language: EN - English
    DVD Subs Language: EN - English
    Chapthers Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: E: Optiarc DVD RW AD-7240S 1.03
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Save Log file: 1
    Unload ActiveMovie library: 0
    Adjust ffdshow mixer: 1
    TITLE 1 SOURCE FILES
    Video: C:\Temp\Azureus_DLs\Up_2009.mkv
    Info: AVC - 4833 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:36:38 hours - 139158 frames
    Audio: C:\Temp\Azureus_DLs\Up_2009.mkv
    Info: Vorbis - 80 kbps - CBR - 48000Hz - 2ch - 1:36:44 hours - Track 2
    Subs:
    [MediaInfoLib - v0.7.26]
    AVISYNTH SCRIPT
    Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("C:\Temp\Azureus_DLs\Up_2009.mkv", CacheFolder = "C:\Temp\Azureus_DLs\junk")
    #Forced 'FFAudioSource' to extract secondary Audio Tracks
    Audio = FFAudioSource("C:\Temp\Azureus_DLs\Up_2009.mkv", track = 3, cachefile = "C:\Temp\Azureus_DLs\junk\A2DFFA_" + String(Rand()) + ".cache")
    Video = Video.ConvertToYV12
    #Using DGPulldown to upsize FPS
    Video = Video.Spline16Resize(720,480)
    Audio = Audio.Normalize()
    AudioDub(Video, Audio)
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: QuEnc CBR 1-pass
    Target Video FileSize: 4046.2 MB
    QuEnc Parameters: -i "C:\Temp\Azureus_DLs\junk\UP 2009_0_Up_2009.avs" -o "C:\Temp\Azureus_DLs\UP 2009_0_Up_2009.m2v" -b 5848 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 9 -priority 5 -auto -close
    <3/24/2010 8:04:12 PM>
    PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
    CHECK LOG FILE <C:\TEMP\AZUREUS_DLS\UP 2009_0.LOG> FOR MORE INFO.
    Log file created by AVStoDVD Release 2.2.6
    Apr 2004
    Miskatonic U
    It is either because you don't have FFDShow set up correctly, or because AVStoDVD has detected that you are trying to convert and illegally downloaded movie
    Read my blog here.
    USA
    This appears to be a downloaded copyrighted video and if so would be in violation of our rules.
    Please read our rules before posting. Thread locked.
    Moderator redwudz
